RCU Forums - View Single Post - 0.S. 91 FX problems.....HELP
Old 02-21-2005 | 07:45 AM
Spicoli
Default RE: 0.S. 91 FX problems.....HELP
Shogun,
I think your engine is transfering heat to the needle valve and causing bubbles in the fuel line.If you are getting bubbles in your fuel line cut off the needle valve and let it dangle.The newer needle valves have a plastic piece that stops the heat from transfering from the block to the needle valve.
