RE: Futaba 9cap question
Just go to the P-Mix page by hitting the menu button a second time, select a P-mix, activate it. Select you master and slave channels, Set the channel activation to your gear switch so it only functions gear down and dial in your mix percentage. I usually setup opposite this however, I put steering on 4 and rudders to the mixed channel which allows trim adjustment of the NG without affecting rudder center. Questions?
Todd
