Originally posted by IronCross
I still have the first one.. Still flying it.. I made a tail dragger out of it and did some repairs on it and it has gained a little weight in the process.. I am running a 46fx in it. I want to modify the nose gear as you did and straighten a few other things out from the git go on this next one. The one I have now also has around 3/4 an ounce of lead in the nose. Probably because I cut the elavator apart to straighten it and then used a lot of epoxy to put it back together. I have an Irvine .53 that is just sitting around also. I am looking for a lot of torque (verticle). Figure I can replace the lead with the slightly heavier Irvine.
I'm using a .46 FX in mine as well. I went with an 11x6 prop yesterday and was very happy with how it flew, vertical is outstanding with this set up! I have never had to mess with the CG of either plane, got lucky I guess. The sun is coming out, I think I'm going to head to the field shortly!
