Adjustable Servo Link?
On my NexStar, the throttle and nose wheel push/pull rods are adjusted by feeding them through a brass block which has a screw threaded onto it. I know you all know that, but my nose wheel block is not staying on the servo arm - nothing to hold the block in place. My question is, do you know of a recommended fix or should I get a new arm/block?
