RCU Forums - View Single Post - Adjustable Servo Link?
Old 02-21-2005 | 04:31 PM
will
Default RE: Adjustable Servo Link?
I believe your describing an EZ connector. You should have a small nylon disk that is installed on the brass pin that goes through the servo arm. If you don't have the nylon disk, a metal keeper is used. Replacement disks can usually be purchase from your LHS. Check with another R/C modeler in your area, they'll probably give you one or two.
