Crazy Max flaperons
I had the same question and spent some time thinking about it. Here's where I got to:
I use a Futaba 6XA transmitter. I can set up dual ailerons (and flaperons) using channel 1 and 6 so I need at least a 6 channel receiver. I then thought about the fact that my computer radio has mixing so it would let me do master/slave between other channels but...
1 = ailerons
2 = elevator
3 = throttle
4 = rudder
5 = landing gear
6 = aileron
5 is a on/off switch. Only choice would be not using #4 rudder and go from there but with acro plane you gotta have the rudder.
My answer is. Got to have a six channel receiver....
There are other Hitec receivers like the Slim that is not much more than the 555 and it is a 7 channel or 8 with a 'Y' harness'. That's where I'm going. The Futaba RF127DF won't fit even with the case off.
- Bill
