RE: problem in UCD 46 PLEEZ help
First of all there are a couple of questions that need to be answered. What engine are you running and what size prop is on it. In my experience I have not run into a plane no matter where the CG is that wont torque. Some faster than others and that has a lot to do with engine type/size and prop size. Having the CG off only makes it more or less difficult to get the plane in its "swet spot". Once there it should start to TR but again it may be slow or fast depending on how long you can keep it in the spot and your engine and prop size.
