9CHPS processor speed
I currently have a 8UHFS. When I use CCPM with 9252 servos, one servo channel moves slower than the other two when you move the collective very fast (switching servos around doesn't help). I have read elsewhere that this is due to a limitation in the processing speed of the transmitter. It sounds like the first 9CHP had the same problem. Has this problem been solved in the new 9CHPS or does a pilot have to jump to the 9Z to have perfect synch in the CCPM servos?
Rick
