RE: I Put Ailrons on my Slow Stick
installing the servo was as easy as cutting a slot the same size as the servo, then slide the servo on the hole and apply clear mailing tape on both sides of servo, from under the wing. if anyone does this, the best new cg is exatly 4 inches from the leading edge. the 3 3/4 inch cg that the plane used before is no longer any good.
