ORIGINAL: trav83
thankx what about putting it back together????
I just simply slip the brass collet back on the shaft, then the drive washer, put a prop on it and then the prop washer and nut. While holding the crank all the way forward in the case slowly tighten up the prop nut until the prop is very secure...as you would to put a prop on. It's there!
