RCU Forums - View Single Post - hatchs&latchs
Old 02-23-2005 | 12:11 AM
A. J. Clark's Avatar
A. J. Clark
Default RE: hatchs&latchs
If it is a flat cover I lay balsa sheeting on two rails like 3\16 square hardwood. Let the two squares extend past one end cut the other end flush. Use the extended end to hook under the main body structure. On the other end I use a flat landing gear strap across the hatch and main structure.
A. J. Clark
