RCU Forums - View Single Post - How do you mount your engine?
Old 09-13-2002 | 06:59 PM
Sawyer692-RCU
Default How do you mount your engine?
I use a hot pushrod end to score the mount then drill it for the bolts. If it doesn't line up after that, I loosen the bolts at the firewall, tighten down the engine bolts and then retighten, and locktight, the firewall bolts.
