ORIGINAL: trav83
i need to install new bearings in my os max sf 46 i got it all aprt but i can not get
the front prop griper off to get to my bearings help !!!!!![>:]
Get a "battery terminal puller" at the Auto Parts store, and pull off the prop
stud. There is a tapered collet in there, and a puller is the best way to get it
off without damage.
Like Gene said....when you put it back together and tighten it down, it will
once again hold everything tight, as well as pull the crankshaft forward to
provide the correct end-play for the crank.
FBD.
