RE: help! prop keeps falling off
To Crashem......If the starter is cranking the engine the wrong direction then the nut would never get lose. The correct cranking direction, counterclockwise, is the direction to also unscrew the nut. Thus the problem. The nut must be tightened to a sufficiently high torque that the starter cannot losen it while the engine is being started.
