RCU Forums - View Single Post - Valve adjusting question for 4-stroke?
Old 02-23-2005 | 08:19 AM
Gene Chernosky's Avatar
Gene Chernosky
My Feedback: (182)
Default RE: Valve adjusting question for 4-stroke?
If you take the timing cover off you will find two small marks on the shaft coming from the case and see two small marks on the timing gears...line them up.
Make sure the valve clearance is between .001" and .003".
After that it is all about compression and carburation.
