RCU Forums - View Single Post - Switch harness instructions?
Old 02-23-2005 | 08:41 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Switch harness instructions?
jsf135,
Ok, here's how you use the switch harness. Referring to you picture. The connector on the left will go into the the battery connector of your receiver. The upper right connector will connect to your battery. And the lower right connector is to connect a charger to when you are charging the battery.
Hope this helps.
