RCU Forums - View Single Post - Question on Pull-Pull Cable Slack
Old 02-23-2005 | 10:00 AM
sillyness's Avatar
sillyness
My Feedback: (25)
Default RE: Question on Pull-Pull Cable Slack
I think if you cross the cables, that .009" becomes .009" of tightening... you would need to offset the control horn behind the hinge-line by .009".
I am using a 3.5" servo arm and a 4" control horn with my JTEC extra. I will use 3/8" of offest in the servo arm and the control horn will be offset .19" behind the hinge line. Should keep things tight. It is 36" from the servo hub to the hinge line.
Could you plug that into autocad?
