RCU Forums - View Single Post - Skymaster BAe Hawk Fuel system
Old 02-24-2005 | 06:06 AM
  #68
digitech
My Feedback: (10)
Default RE: Skymaster BAe Hawk Fuel system
ORIGINAL: Ali
Sandor. I did see the potential of a similar problem with my hawk but I adjusted the position the actual retract on the bearers so this nipple cleared the wood work. I slid mine as fas as it would go toward the wing tip. Also I notice by your picture that you have raised the retracts off the mounts with washers. What I did was I removed the moulded lip that is on the wing around the retract mount opening. This meant my retracts could sit square on the wood mounts and slide toward the wing tip thus clearing the nipple.
I hope that all make sense. If not I will take some pics later today. Cant do at the moment as camera is flat
Here are some epics of my install. All done apart from the UAT which will hopefully arrive today
Hi ali
i considered the wood but that is not a problem since you just swap the gears left with right and the wood is no problem
it was for me a real mechanical problem
secondly i put the spacers beneath the gear otherwise it will rest on the fiber and not on the wood
now the gear is ok and all works
