This winter projects are
1) MIG29 by AK Models, New Evolution 1.00NX spinning a 14x6 MAS for max thrust for test flight then dropping down to a 12x12 APC for speed.. Mods done: added 1 1/2" to each wing tip and will use Flaperons. Total Dry weight 8.7
2) SU27 by AK Models, Power and props same as above. Mods done so far: Increased the elevators width at the tip by 3/4" with tapper to root, Added 3" to each wing tip ( not using missile rails ). will use Flaperons as well.
If you would like to see the build on the MIG29
[link]http://www.rcuniverse.com/forum/m_2177564/anchors_2177564/mpage_1/key_/anchor/tm.htm#2177564[/link]
and the SU27
http://www.rcuniverse.com/forum/m_21...tm.htm#2186098
This is a pic of the Mig....finished pic of the SU in about a month to be added.
