ORIGINAL: pollemix
A helping hand please!
I bought a UcanDo 46 with a 0.61 OS fx engine on it. Instructions warn you about going higher than a 0.51 but the seller says it flies great with a .61...anyone would like to add a comment?
Next topic: In the aerofly sim the engine spec doesn`t use bhp, instead it uses KW. If my 0.61 engine specs says: Horsepower: 1.90 BHP at 16,000 RPM...what should I use in engine power?
thank u very much for your assistance!!!
I put an OS 91 4-stroke in my U-Can Do 46 size and it is 10 times more fun to fly.
Don't worry about the limits GP puts on the specs as long as you don't fly it at full throttle other than vertical you should be fine and make sure it balances where it should.
