RCU Forums - View Single Post - Sealing hinge lines
Old 02-24-2005 | 01:15 PM
dredhea
My Feedback: (13)
Default Sealing hinge lines
Hi All,
I'm getting to the point of covering my GP Ultimate. I'm using CA hinges, but would like to seal the hinge lines. The problem is that I have no idea what the technique is to do this. Is it as simple as adding a strip of monocoat to cover the joint, leaving the trailing edge of the covering loose? Any help would be appreciated.
BTW, Minnflyer (I know you'll see this), I thought about copying your idea to reverse the color scheme, but have decided to attempt the box photo with the exception of adding color to the wingtips. I would enjoy seeing your version though.
