RCU Forums - View Single Post - Low High Band
Old 02-24-2005 | 03:00 PM
rlipsett
Default RE: Low High Band
Not to really confuse you but hitech flight packs also work with futaba transmitters and do not suffer from Hi or low band problems. Depending on the reciever you buy they will work with the servos of whoevers you have. If you order from tower they can help steer you in the proper direction when you are buying the reciever or flight pack if you let them know you need a little help.
