RE: How To: Calibrate your Accu-Cycle
2rolls your meter wont be on any voltage setting but rather the DCA setting like the one in the pic I've posted. If yours is like this one unfortunatly its max range is 200 ma & you need a min. of 250 + since this is the lowest setting if I'm not mistaken on the discharge of the Accucycle. If you try to use it there is a little fuse inside that will blow more than likely. It may handle the 250 + or - mills but if it dont all you will be out is a 50 cent fuse.
You will however be able to hook it up & check the charge rates to see if there acurate since the max there is 125ma
