ORIGINAL: RCIGN1
If the switch was off no current was going to the ignition anyway.....
I hooked a voltmeter up to the igniton lead and plugged the pack into the charger and the reading was 0.0 because like RCIGN1 said the switch was off..I turned the switch on and I got a reading of 5.2 which is what my regulator is set to!! So even if there was current into the igniton it was only 5.2!!!!
