Dude, don't count on that completely solving your problem. I did it and it created my problems. Hitec would never admit there is an issue with their servos however once you lose a plane or find the problem before hand they will gladly fix or replace it. If you do program them make sure you throughly test them before putting your plane in the air. Your right though, if they would admit it and recall the bad servos then we would all be happy but we all know that won't happen...
I'd hate to see your plane look like this because of servo failure... The plane had 4 sucessful flights then I reset the servos. On the 5th flight the left aileron servo held the aileron up causing the crash.
