RCU Forums - View Single Post - 5625 Problem
Thread: 5625 Problem
Old 09-17-2002 | 04:30 PM
MikeMayberry's Avatar
MikeMayberry
Default 5625 Problem
I have. Here it is again.
Important Information Regarding Digital Servos
While Hitec strives to deliver high quality products that work universally with a wide variety of other manufacturers equipment we occasional run across a compatibility issue with products other than our own.
In light of this it has come to the attention of Hitec, that our digital servo product manufactured prior to October 2001 may act erratically when used with a non Hitec computer radio where the user has programmed the ATV settings beyond 125%.
As a result of this finding Hitec would like to extend an offer to all owners of our digital servos built prior to October 2001. If your servo has the following identification labels on it, they will qualify for this free reprogramming service.
The affected servos are labeled as"Modified" with the dates listed below:
APR2001
MAY2001
JUNE2001
JULY2001
AUG2001
You can return your servos to the Hitec service department for reprograming with the latest software version, or you can upgrade the servo software yourself, using the RESET function of the Hitec HFP-10 Digital Servo Programmer with software version, 1.03 or higher. This will "update" your servo and should fix any known conflict with the non-Hitec equipment.
Additionally any HFP-10 programmers that contain a software version earlier than version 1.03 can be upgraded free of charge by by returning it to our service department in Poway, California.
Mike.
