5625 Problem
747drvr- At this point I would recommend you update the programming just to be safe.
WreckRman2- I know you are upset and I would be too if I lost such a beautiful plane. However, your insinuation that there is a "known" problem and that we should recall all the "defective" servos is way off base. Hitec has literally sold 10's of thousands of digital servos and very small amounts have had any problems. However, since most of the digitals go into more expensive airplanes, if one fails it gets more attention. I believe your problem possibly came from resetting the program through the extension.
Mike.
