RCU Forums - View Single Post - The TRUE cure time of epoxy...
Old 02-25-2005 | 01:57 PM
bruce88123
Default RE: The TRUE cure time of epoxy...
If you are going to thin epoxy with alcohol use "denatured alcohol", available at Home Depot I believe, as it contains no water and use sparingly. Keep alcohol tightly sealed when not in use as it is highly "hygroscopic" like your fuel is.
