RE: Question on Pull-Pull Cable Slack
OnTheEdge said exactly what I was thinking as I read through this thread. Typically you're not going to do a tail slide with the rudder fully deflected and even if you do, the opposing air pressure on the rudder will be very gradual as there is zero air speed when the plane begins to slide. Highly doubtful this will even be close to doing any kind of damage.
