RE: good first arf
You already own a Stryker correct!!!! How is the fuselage on it etc?????? If there is nothing wrong with the fuselage etc then you might want to look into just replacing the radio gear,servos and motor with nonpropriety gear. Use a regular radio system such as something from Hitec. A set of hitec 55 servos. a Berg 4 dspII receiver a 25 amp speed control for a brushless motor and do some searching for the most commonly used brushless motors in the stryker. This will put your Stryker into a whole new level of flying aircraft.
I would not recomend using the ParkZone radio or any of its gear on arf models. If anything I would keep the ParkZone model and swap out the radio gear for something more widely used. You get much better performance.
