RE: Epoxy experts only
Unless it is an epoxy system like West Systems which has multiple hardeners and a single resin do not mix and match. Epoxies are formulated as a system that will only work well when the proper parts are mixed in the proper ratios. Even 5 minute epoxies from diferent companies may not work well if you mix part A from one company with part B from the other company.
TFLG
