Nylon steering block question
I am finishing a SIG Kadet ARF. We have bought a fults gear which is a 5/32 wire. The factory steering block is much smaller and also the holes have been pre-drilled in the firewall with blind nuts installed for the factory block. Is there a adjustable steering block that will accomodate the 5/32 wire? The outside to outside dimensions on the factory block mounting holes is 15/16" and up to down is 3/4". I drilled the factory block but I got a little off center. "Its Junk"!
Perry
