RCU Forums - View Single Post - GP Super Stearman
Old 02-26-2005 | 09:32 PM
  #256
mga
Default RE: GP Super Stearman
That's the problem. I am getting about 1 inch and less that a half inch on the bottom wing and on the top wing an inch and a half and same on the down part. What measurement is the rod from the bottom ailoron to the top one. what is the distance from the trailing edge of the ailoron to the the clevis on both the top and bottom ailoron. For some reason I think the measurements they are giving in the book is wrong. Could someone give me their measuremnts Install the Aileron Connecting Rod. instructions no. 4 and no.9. those measurements from the trailing edge. I want to make sure if I have it right and somehow not getting the proper throws.
I also changed the hinges to Robarts, as I am going to install a First Place 2.4 gasser. As the plane will weigh about 15 lbs, it will be a good engine to have in it.
