RCU Forums - View Single Post - Trainer keeps wanting to climb, how to trim a plane q's
Old 09-15-2002 | 04:24 AM
99GrandTouring
Default Trainer keeps wanting to climb, how to trim a plane q's
I posted before in another thread about prop sizes that my new xtra easy arf keeps wanting to climb...
it was suggested that I add some downthrust but after looking at the engine/mount/firewall I've noticed it already has a TON of downthrust added... The firewall sets at about a 80 degree angle if the nose were 0 degrees and the tail were 180 degrees.....
So here is what I ask, I used to have an old us aircore knighthawk that had flaps, whenever you kicked in the flaps it would nose up and climb....
I've looked at my ailerons and noticed that centered they both are down like flaps by maybe a 1/16th of an inch at the very trailing edge... If I were to adjust them to where they were say 1/16th of an inch up, both sides would this help?
In order for it to fly level you have to have full down trim and about 15 points down trim in the comp radio (jr XF421ex)??
Or would this be a bad idea? Thanks!
