Trainer keeps wanting to climb, how to trim a plane q's
99GT
On the two Xtra Easy's that fly at our field, we have found that they needed a 1/16" shim under the trailing edge of the wing.
Set the ailerons level with the trailing edge ane fly it. If it still climbs put a 1/16" balsa shim under the trailing edge and fly it.
After you find out how many shims are needed just glue them in place. I shouldn't take more than two.
Let us know how it comes out.
DEG
