RCU Forums - View Single Post - Trainer keeps wanting to climb, how to trim a plane q's
Old 09-28-2002 | 12:34 AM
99GrandTouring
Default Trainer keeps wanting to climb, how to trim a plane q's
well tonight I'm gonna take off the gear and lay the fuse on my workbench (the bottom of the fuse is flat)
and measure from the front of the stab to the bench
and from the rear of the stab to the bench
Then I'm gonna measure from the leading edge of the wing down
and from the trailing edge down..
I'm gonna try to build up both....
Make the wing at almost 0 incidince maybe 1 degree positive and make the stab at 0 or -1 incidence...
If I think correctly if the wing was at positive incidince (leading edge sets up higher than trailing edge)
and the horizontal stabillizer had negative incidence (Front of it was lower than the rear)
It should create a plane with the dynamic forces for it to want to keep climbing, like my plane is doing....
Is my theory correct?
