Well.....
I was just going to set everything to a "neutral" type setting
The only thing is, if it has to be related to the thrust line of the aircraft, its gonna be hard.......
The reason is because if you notice on an extra easy it has a large amount of downthrust incorperated into it. The Firewall has a very forward slant to it.....
Hmm..... now this changes things.. I'm not gonna go hacking the firewall....
I'll check out the wing/stab first make some adjustments a little at a time and see.....
