RCU Forums - View Single Post - OS .46FX Engine troubles
Old 02-27-2005 | 02:04 AM
Ratt Belly's Avatar
Ratt Belly
Default RE: OS .46FX Engine troubles
Guys,
Be sure to check and make sure that the fittings that hold the fuel line between the remote needle valve and the carb are both tight. On both a .61fx and a .40fx that I own these fittings were loose causing air to be drawn in resulting in similar problems that you are experiencing.
Good Luck.
