RCU Forums - View Single Post - Nylon steering block question
Old 02-27-2005 | 01:40 PM
ballgunner 's Avatar
ballgunner
Default RE: Nylon steering block question
Order a new nose wheel mount from Sig and be nore careful when you drill it out. If you don't have a drill press and a drill press vise find a friend with one. I've used Fults nose gear on three Kadets but none of them were ARF. Good gear if you put the nosewheel on the ground first by mistake. I found from the first that the little screws that hold the axle in can come out and give you some excitement when the axle falls out of one side. I soldered mine in place after the first time it happened to me.
