RCU Forums - View Single Post - Lipos in parallel ?
Old 02-27-2005 | 02:14 PM
jtemple42000
Default RE: Lipos in parallel ?
Mac8,
You are correct. If you want to make more voltage you connect positive to negative, if you want to create more capacity, or mAh, you connect all the positive terminals together and all the negative terminals.
pikeman401,
I agree with you. I use lipos and all of my 3S1P packs are 11.1 volts not 12.6. I'm not sure where he gets that number. I'm not saying that it is wrong, but I haven't seen a 12.6v lipo. Individual cells are 3.7 volts, I thought......
