RE: 9C setup/mix question
I tried this but it doesn't seem to work. In PMIX, if I set the slave control to Flap, only the right alieron moves. If I set the slave control to Aileron, both ailerons move, but they move in opposite directions. The problem with using two PMIX's is it doesn't seem to treat the ailerons independently, you can't program them independently. If I could find a way to control the left aileron somehow, this would work. Thanks for the suggestion! I thought this was going to do it! Anyone else?
ave-
