RE: Cermark CEM-600BL-2
Hi,
I have the cermark 600bl2,same geabox and APC 16x8 prop, CC60 SC, and 3s2p 6000mah lipo in a banchee.
I get 6800 with this setup at 5000 feet in denver.
It pulls 5+lb on the ground for info. In your lightweight 2.25lb plane you have mega power.
I milled a flat spot the motor shaft where the pinion set screw goes on, the pinion set screw then fits better.
For info, when you tighten the gear box to motor be careful of not overtighening the bolts, the alumium in the motor is soft.
Found this out the soft way!!
I made a milled alumium motor mount for it, very light weight.
I have several I am getting ready to sell for the AXI's, 10mm round nippy,pjs and other mounts to bulkhead and 10mm booms. enclosed pic of a few protos, I am going to make them lighter than the one shown. I have other styles in the mill right now.
[img][/img]
Tony
