RE: How to create 0 up down balance?
For the vertical placement of the CG, I would base that on hovering (assuming no up/down thrust) because KE coupling arises from many many other things. Most planes you'll find you have to hold a little up elevator in a hover, or at least input up elevator more often than down elevator, largely due to the vertical CG.
