RE: Rascal 110 with MVVS 1.60 gasser pics
Hi
YOHH :
The weight without fuel is about 13.5 lbs but the plane has 3 1100 mAh Nicads - this is really not a problem, it is still light in the air !
I am using a 18x6 and stayed with the stock fuel tank (just put in a gas bung) The stock Sig spinner internals were to small for the 18x6 and I replaced it with a Protech Aluminium
one.
This is the 4th 110 Rascal at the club so I made one or two very minor mods - I will take pics and post them.
a65l: You should see how flat this baby turns !!
Kmot: Had to make the mufflere as I could find nothing even close - actually had to make 2 - found out you cant really weld on the muffler once its been used - seemingly due to the oil.
