RE: Ultrafly Cessna 182 ARF
Hey Mukradio thanks for the post and I echo Phil's comments....let's see some pics man !!! also what Mtr , ESC, etc are you using and what wing did you use for the madien. I am going to use the begginer wing and larger prop just to trim the plane out and experiment with a couple different batteries. Then use the sport wing and 8" prop. I did get a lot done this weekend so the plane will be ready for sure this weekend. Hey both you guy's did either of you go with the tricycle gear set-up ? Just curious as I am going too but have to reconfiqure as I cut the plastic support bars for the battery because I am going to use bigger non flat type packs...Will post the pics when done later.....Kevin
