RE: Vectorflight Edge 540 build
Hey guys, Almost finished with my Edge and it's looking great. I used VF's new bellypan mounting method and it seems to have worked well.
I do have a question on the Aileron control horns........Usually, I try to line up the control horn so that the holes for the clevis are over the hinge line of the control surface.....if I mount the control horns behind the wing servos, this won't work, because the aileron is on an angle. However, I could mount the horns further out on the control surface, and that way, I can mount them lined up with the front edge of the aileron. How did you guys do it?
