HOVER WOBBLE
I HAVE RAPPY 30 V2 WITH MAVERICK PRO CARBON BLADES. I HAVE PUT A GALLON OF FUEL THROUGH IT WITH NO PROBLEMS, THEN YESTERDAY I FILLED UP WENT OUT TO FLY AND SPOOLED UP TO GET THE BLADES EVENED OUT, TIGHTENED THEM DOWN AND STARTED TO HOVER. WHILE IN THE AIR ABOUT 6' OFF THE GROUND I NOTICED A WOBBLE FROM SIDE TO SIDE, I LANDED AND CHECK THE BLADES, LOOSENED THEM UP AND SPOOLED UP AGAIN, AND LOCKED THEM DOWN AGAIN, AND GOT ABOUT 6' AND SAME THING??? I ADDED A LITTLE MORE THROTTLE AND BROUGHT THE HEAD SPEED UP A LITTLE AND IT STOPPED. SO I LANDED AND ADJUSTED THE PITCH CURVE SO I COULD GET A LITTLE HIGHER HEAD SPEED AND TOOK OFF AGAIN AND SAME THING UNTIL IT GETS A HIGHER HEAD SPEED. HAS ANYONE GOT ANY IDEAS ON WHAT IS CAUSING THIS??? THANKS IN ADVANCE.
CHRIS
