RE: Need some help...
Chris,
The pigtail is a Deans UltraPlug female soldered to two 18ga wire, one red and one black. The other end of the wire is loose so you can solder it onto your battery terminals. If you are not comfortable with this then I would suggest you get some batteries with a Deans UltraPlug female as the output plug already configured for you.
