RCU Forums - View Single Post - Inside loop cuts engine off
Old 03-01-2005 | 12:38 PM
galaxyob1
Default RE: Inside loop cuts engine off
Greetings,
For those who read about my problem with the Fox 35 on the Galaxy here is an update. After several attempts to get the OS loop and engine to work I ended up rotating the Fox 35 vertical last summer. This was done after a few needle valves and fuselage repair. The plane and engine work pretty good now and its fun.
Since then I have also worked with the LA 25 on a ARF flite streak and I built a Brodak Tomhawk. The LA25 work good, but I put a smaller venture on it to slow it down, it works for me. Here's a question on trimming the Tomahawk, the fuselage moved on me when it was glued and I caught it too late. The fuselage is about 5° to the left, to compensate I made sure the elevator flaps were parallel to the wings, so a few things are square. The Tomahawk flies with the o/s wing listing up, I see more than the profile. Can and should this be straitened out? I've seen an OTS stunt Eldiablo at Columbus with some added o/s wing flap. It this what needs to be done?
