ORIGINAL: Morpheus56692
I've been playin G2 for awhile. I purchased G3 and now I'd like to network these two together for a little pylon racing. Can you network (LAN) G2 with G3 together?
No, sorry.
And if not, can you network (LAN) G3 and G3 together?
Yes, that will work. One computer will the the host. On this computer, choose "host" from the multiplayer menu, then on the next dialog, leave "broadcast to the list server" unchecked. Your host will then be visible only on the LAN. The second computer should choose "join" from the multiplayer menu. Change the dropdown list to the left of the "search" button from "Listing Server" to "Local Network". Then click search. It should find the host you just created. Double-click on it and you're connected.
